Error 61024 occured at niLvFpga_Open_cRIO-9111.vi:5110001
I am trying to achieve PMU functionality using cRIO 9068 with NI 9242, NI 9238 and NI 9467 modules. I want to set up a LabVIEW application to observe the signals and timestamp them. I downloaded the power_monitoring_starter_kit and followed the instruction to delete the example modules and add my modules in the starter kit. Once I do everything and run the main VI I get an error "Error 61024 occured at niLvFpga_Open_cRIO-9111.vi:5110001". I have attached couple of images for reference. My guess is I am using cRIO 9068 and the program has cRIO 9111 which is creating an issue. I need help to resolve this. Also, I have a very basic knowledge of LabVIEW.
(2,319 Views)
Hi djoshi5
Here is a document that outlines common solutions to this error.
Additionally, you would get better visability if you post on the Real Time Forum.
All the Best,
Noah B.
http://www.ni.com/support
Noah B.
Technical Support Engineering
(2,287 Views)
