Error -61499 occurred at niFpgaTimingViolation_InitializeHighlightData.vi
I am a veteran LabVIEW FPGA user and lately I have been having a problem getting a certain vi to compile.  A certain VI of mine written for the PXI-7953R target always fails to compile with a timing violation.  Whenever I click on "Analyze timing violations", I get an internal error message and no information to determine how to fix my vi.  A part of me is thinking that there is a component or indicator that is forgotten somewhere on the screen and is too far away from my main vi "island" to find/see it.  Any advice from anyone?  I have attached my error log files.
Possible reason(s):
An internal error occurred. Please try again or contact National Instruments.
Details:
Error Code --> -61499
Error Text --> <APPEND>
Additional Information: There is no matching tag in Xilinx twx file
Return Code:-3003
(3,619 Views)
Update:
In my program, I was reading from a PXI Trigger line from withing a single-cycle timed loop that was going 125 MHz.  I disabled that function and repaced it with a FIFO read and it compiled!  Now I know what is causing the problem.
I have attached a VI snippet of the sub-VI.  Look at the second loop.  I will try to re-create my Trigger and see if it will re-compile successfully.
-John
(3,610 Views)
Accepted by topic author John80
It makes so much sense now too....
The PXI Trigger runs inside a 10MHz clock domain, and my other loop, the one which was accessing this Trigger line was running at 125MHz!  So obviously that was a problem.... I pulled the PXI Trigger out of that loop and placed it into a slower and compatible loop running at 40 MHz and my problem is now gone.  If only LabVIEW FPGA would have told me that sooner...
-John
(3,597 Views)
