Error 62 in TCP Write
Accepted by topic author Zsmathers0211
I found a solution that lets each command execute without error! Using a type cast with a numeric constant of 0 as "x" and put into a "concatenate strings" bottom input with the command and null character in the top input of the concatenate strings box. This fed into the "data in" input on a TCP Write has worked and I'm not sure why but it does. Thanks for everyone's support as I'm sure those changes also helped.
Message 11 of 11
(261 Views)
