Error 64 Serial Port Framing Error
I am trying to communicate with a CompactRIO unit using LabVIEW Real Time being controlled from LabVIEW running on a Windows PC.
I get the following intermittent error in the communication between the LabVIEW for Windows and LabVIEW Real-Time communications.
Error 64 occurred at TCP Read in RTCW TCP Send Receive.vi->NPL_Motor Velocity Control- Function Generator as Blender no PID(RT).vi
Possible reason(s):
LabVIEW:  Serial port framing error.
LabVIEW:  The network connection is not yet established.
Any pointers would be greatly appreciated.
A.
(3,226 Views)
Hi Joe:
Does your Time Critical Loop sleep for a sufficient amount of time? I would try to see if the problem goes away if you increase your wait inside the TCL.
This discussion forum thread might help shed some light on the issue:
http://forums.ni.com/ni/board/message?board.id=170&message.id=68901&requireLogin=False
Jaideep
(3,212 Views)
