Error 7 during build application
I upgraded from 8.2 to 8.5 a few weeks ago. Since then I have been unable to build an application I have been working on. I get the error below almost immediately after trying to build the application. I have tried building this on two seperate machines with 8.5 and get the same result. I can go back to 8.2 and it builds fine. I tried doing a mass compile with 8.5 with no success. I can run the top level vi with no error. LV seems to be looking for a file and can't find it, but I don't know what file it is looking for.
ERROR MESSAGE:
LabVIEW cannot find a file that is a dependency of a Startup, Exported, or Always Included VI.
File Not Found: .
The missing file might be referenced by one of the libraries included in the build or by the file - AutoScope.vi. To fix this issue:
- Open all Startup, Exported, or Always Included VIs, recompile them (CTRL+SHIFT Click the Run arrow) and save them to update their dependencies.
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at AB_Engine_HandleLinkErrors.vi -> AB_Engine_Update_Source_from_Linker.vi -> AB_Build.lvclass:CalculateDependencies.vi -> AB_Build.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
Message 1 of 17
(9,119 Views)
When you tried to build the app on the other machine, did you recreate the build spec or use the one in the project?  I have seen cases where I had to nuke the build spec, do a mass compile and then recreate the build spec.
Message 2 of 17
(9,109 Views)
Just tried with a new build spec and I get the same error.
Message 3 of 17
(9,106 Views)
That looks familiar.
See this thread for what i saw.
A repair of the LV install may help.
Please let us know if this is the same issue or if this is a unique bug.
Ben
Message 4 of 17
(9,106 Views)
I tried creating a new LV project and I get the same error. I did uninstall everything prior to installing 8.5. I'll try to have someone else build this on a different machine.
Message 5 of 17
(9,099 Views)
I get the same error on a different (third) machine.
Message 6 of 17
(9,086 Views)
The LabVIEW Application Builder 8.5 release notes have a possible solution to your problem.
Message 7 of 17
(9,031 Views)
Hi Collin,
You mentioned that you did a mass compile with no success.  Was the mass compile unsuccessful?  Or the build after mass compiling?
Message 8 of 17
(9,003 Views)
I think this is an 8.5 issue. If I create a blank vi, and then add a static vi reference, and point the static vi reference to the containing vi, building an application using that vi causes an error. Attached is a vi that demonstrates this. If you try to build the attached vi into an application it will fail if using 8.5. It will not fail when using 8.2.
Message 9 of 17
(8,998 Views)
This error typically occurs if a project library that is being added to an executable (whether it was added explicitly or as a dependency) is missing a file. A library with a missing member is not technically "broken" so it can load ok (and I believe mass compile will not report that as a problem). But when you are adding the library as part of an executable, a missing member may cause a problem. I woudl first check any libraries you are using as part of the build to see if any of them have missing files. I would also try to adjust the Additional Exclusion settings  - "Remove unused members of project libraries".
George M
Message 10 of 17
(8,995 Views)
