Error 7 during the build. LV 8.6
I've read quite a few threads about errot 6 and 7 during the building process however they not answer my case.
I'm building the code distribution with no excluding the instr.lib user.lib and vi.lib files. At the end of the build process I'm receiving the error:
Error copying files.Source: C:\PRJ\National Instruments\LabVIEW 8.6\resource\visarc
Destination: C:\PRJ\Builds\PRJ_Source_Distribution\C\PRJ\National Instruments\LabVIEW 8.6\resource\visarc
source does not exist
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a
reference:
Error 7 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_FRAMEWORK.vi -> AB_Item_OnDoProperties.vi -> AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
It didn't surpise me because I don't have the source folder C:\PRJ\National Instruments\LabVIEW 8.6\resource\visarc. It did surprise me bacause the builder expects the source to be there. Could someone can explain me why it happens?
(4,388 Views)
Accepted by topic author MimiKLM
Hi MimiKLM,
Sorry for the delay in getting back to you!
As you have copied below, error 7 will be thrown when LabVIEW cannot gain access to the specified source file.  There are a couple of possible issues;
Operating System
  • If you are using Windows 7 or Vista, try running as an administrator.
  • Similarly ensure the file path is no longer than the 260 byte maximum.
NI-VISA Property Nodes
  • Are you using any of these?  KnowledgeBase article 4VO88IPJ highlights an issue associated with creating a source distribution similar to this, and gives a possible solution.
I hope this helps, let me know how you get on.
Peter D
(4,356 Views)
Yes, that was it http://digital.ni.com/public.nsf/allkb/833BFD5E9CA0224886257584004DAA4C
Mass compiling with modifying the LabVIEW.ini file.
Thanks!
(4,318 Views)
Also happened to me in LV2019.
Strange behavior, hard to reproduce. Turned out to be a corrupt project file. This probably happened during some crash or such, been working for 1 year on this very large project. Revision count ~2000...
Starting a new -blank project- copy file structure into this project file, then reconstruct the builder from scratch solved the issue.
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
(2,253 Views)
Merging .lvproj files (and their ilk, e.g., .lvlib, etc) with versioning software can cause corruption if they are not marked as "binary".
Bill
CLD
(Mid-Level minion.)
(2,245 Views)
Thanks for your info Bill,
In my case no version control or such is used. However LV sometimes crashes, hangs & requires hard termination or moving folders/lvlibs can cause some corruption in the project file. This happened in my case.
Nearly everything was still working fine, but when building with [VersionNumber] in the path, some strange things started to happen...
(as today was the first time I included this function in the .exe builder this project started to act strange where others were fine... took me some time to find out the root cause.. fixed now)
(2,241 Views)
