Error 7 looking for "CMP Compare Hierarchies.vi" when comparing VI hierarchies
That file is nowhere in my National Instruments directory.
What's a good fix for this?
Message 1 of 17
(3,643 Views)
Do you have procmphier.llb   (  ...\LabVIEW xx\project\procmphier.llb)?
That's where it resides in LV6.1.  Might have changed in newer versions.
Fading out. " ... J. Arthur Rank on gong."
Message 2 of 17
(3,628 Views)
Hi bmihura,
For LabVIEW 6.1, 7.0, 7.1, and 8.0, the CMP Compare Hierarchies.vi is located at C:\Program Files\National Instruments\LabVIEW x.x\project. The VI resides in the procmphier.llb library file.
Best Regards,
Jonathan N.
Message 3 of 17
(3,621 Views)
Sure enough, that worked, thanks.
Is there an easy way to report bugs online?
There's a minor bug where the names of VIs in the warning box won't fit if their paths are too long, and there's no way to expand to box or otherwise get at the VI's name.
Message 4 of 17
(3,615 Views)
Hi bmihura,
We do have a Product Feeback section our on website where you can provide R&D with your thoughts and issues.
Best Regards,
Jonathan N.
Message 5 of 17
(3,605 Views)
I've the same problem and do have the file procmphier.llb in my C:\program files\Nation Instrument\LabView 7.1\project directory and it still not work.  Is there any suggestions on what should I do?
Message 6 of 17
(3,580 Views)
I'm able to run "procmphier.llb" directly, try that.
Either LabVIEW lost its internal link to that LLB file, or the LLB is corrupt. LLBs self-destruct sometimes.
Message 7 of 17
(3,569 Views)
How do I run "procmphier.llb" directly?  I tried to double click on the file but it kept giving me option to run the file.  Is there any special things I need to do in order to run the ".llb" file.  Please give me instructions.
Message 8 of 17
(3,562 Views)
If you have LabVIEW installed, it is supposed to open when you double click it.
Try opening it through LabVIEW:
1. Create a new black VI.
2. Select "File >> Open...".
3. Browse to that LLB file, and open it.
Message 9 of 17
(3,551 Views)
That work.  Thanks.  I tried to compare two VI hierarchy and get the following error:
Error 7 occurred at Invoke Node in CMP Get VI Hierarchy.vi->CMP Get VI Hierarchy Correspondence.vi->CMP Compare Hierarchies.vi
Any idea what is this error is about?
Message 10 of 17
(3,548 Views)
