Error 7 occured at Advapi32.dll-source does not exist.
I'm using LV 6.02 and W2k Sp2. I'm trying to build an application that worked fine with Sp1. Any idea?
Andras Ferencz
(2,646 Views)
Are you trying with the correct path? If your vi is included in a llb, you must know that current path function gives the name of the llb too, and if an executable, current path gives the exe name in the path, so you must handle this.
Hope this helps
(2,646 Views)
