Error 7 occured at new file
So I've written a VI that communicates with an intrument using downloaded drivers that originally ran fine. I moved the VI from the original location to the desktop, and copied the drivers to that location as well. I keep receiving this error message regarding the file. I am sure that I have messed up the file path. Could someone help me on how to fix this and get the VI to run properly. I think this is a common mistake and I just need to know where to move the files.
Thanks!
(3,383 Views)
Hi ngorg,
why did you move VIs to the desktop?
Which file do you talk about?
(3,381 Views)
We can't help you fix a VI to run properly when you haven't attached the VI to be fixed.  Also give some more information such as where was the original location?  What is the file path you are sure you messed up?
(3,378 Views)
Actually I figured it out on my own, but thanks for the replies!
(3,357 Views)
Hi ngorg,
a forum like this one lives from replies, where users actually tell their solutions!
Do you mind to tell us how you solved the problem?
Maybe the next one with the same problem is able to find and use your solution…
(3,351 Views)
