Error 7 occurred at Get LV Class Default Value.vi only in my executable for Print Report - LV 2010 SP1
@RavensFan wrote:
So that is good.  You searched, and you found a message and that took you to the link you needed.
My thought exactly. I would call that a win on all sides.
___________________
Try to take over the world!
Message 11 of 14
(1,475 Views)
Yup. Fixed my problem too. The amount of searches that lead me to post that ask if the OP searches is just getting insane; that is all.
Message 12 of 14
(1,466 Views)
It just proves that the information is out there if people actually bothered to search before they posted the question.
Then they wouldn't need to be told to just do a search.
Spoiler
How many more times does someone need to ask how to read an Excel file as if nobody had ever asked that questioned before.
Message 13 of 14
(1,461 Views)
If the problem is that I suggested the OP should have searched rather than just giving the answer (which I did do), then I won't accept that as a legitimate complaint.
It may be annoying to repeatedly seeing something which may seem condescending (like "why don't you search?"), but it's at least as annoying to have people ask questions when they should be searching and spend your time on answering those questions. The best way I know to get them (or others reading) to at least search in the future is to say so, and that isn't always coated in a pill of niceness (not that I was being not nice there, mind you. At most I would say I was terse, and even that is stretching it). I generally don't like the regulars being rude, but I don't think this qualifies.
Not to mention that even that didn't seem to help, because in the next reply I had to suggest a search again, so you can't win 'em all.
I can personally say that if I'm searching for something and the first result I get is from some forum somewhere and it points to an MSDN article and is also asking the OP if they tried searching, I'm not annoyed at all by that, because a) it's justified, b) it doesn't apply to me and c) I got the answer I actually wanted.
___________________
Message 14 of 14
(1,452 Views)
