Error 7 occurred at Open File+.vi: Open File.
Hello everybody,
I'm working with Labview 8.5.1 under WINXP and I've got a benchtest wich is working well since lots of years. I generate an executable and this executable is working well on my computer and other computers under WINXP (about 5 different computers).
But now we bought some new computers and they are under WIN 7 64 bits. Now when I lauched the same executable, I've got this error message :
Possible reasons:
LABVIW: file not found. Or
NI-488: non-existent board.
So, I searched on labview forum's and found differents post like this one :
http://forums.ni.com/t5/LabVIEW/Error-7-occurred-at-Open-File-vi-Open-File/m-p/1219184/highlight/tru...
I've corrected my code and the message apears again.
Does someone have an idea witch could help me?
Fabrice
It's very strange. Why is the exectubale working on XP and not in WIN7?
The trouble is can't do some debug with the executable to find witch function isn't working.
Message 1 of 8
(7,284 Views)
One reason might be that LabVIEW 32-bit resides in the "Program Files" folder on 32-bit Windows and "Program Files (x86)" on 64-bit Windows.  If you have any hardcoded stuff, you could get tripped up.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(7,278 Views)
Hi neo,
Why can't you?
When it's your EXE you should include a simple MessageBox showing the filepath that can't be opened in case of an error…
Message 3 of 8
(7,275 Views)
@GerdW wrote:
Hi neo,
Why can't you?
Agreed.  Add real error handling.  When you build an executable the default behavior is to leave all the error handling to you.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(7,272 Views)
You are right, with a simple message box, I can check this and I will check this quiclky.
I'm agree with the directory Program files is changed under WIN7 in Program files (X86) but what I don't understand is all of my files in input are on the desktop of the computer.
Very strange!!!
Could it be because every drivers I've installed are inside Program files (X86)?
Thanks for your help,
Fabrice
Message 5 of 8
(7,260 Views)
The actual folder location of the desktop also got moved going from Windows XP.
Message 6 of 8
(7,256 Views)
Dear everybody,
After using lots of messages boxes to find where was the mistake, I've found it : It was a trouble of right.
On my software I had to put on c: \ a temporary file.
But until I was administrator on my  computer when I copy a file WIN7 asked if I was sure to copy it. But on LV8, there were no message and the file wasn't copied.....
So I've changed the directory to an allowed one and now it's ok..
Thanks a lot for your help.
Fabrice
Message 7 of 8
(7,172 Views)
You have a worse problem.  You have no error trapping.  Take some time.  Do it right.  If you had ewrror trapping in the first place, you probably wouldn't have had to come to the forum.
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(7,152 Views)
