Error 7 occurred at Open File+.vi:open path
Hello Everyone,
I am facing this error and unable to counter it even going through many treads people posted in the past. I am attaching my code and supported files for LabVIEW master's to suggest how to get rid of this error. I think I am giving right paths to the folders but code still gives this error. Interestingly I am getting partially right output.
(2,824 Views)
Hi Hassan,
Did you try to debug your VI?
There are not so many places where an "Error 7 at OpenFile" could happen!
I did that for you and found the problem: you are trying to access a non-existing file with your VI. When trying to open a non-existing file you will get error 7 ("file not found" as it says in the error description!)…
(Hint: the error only occurs with your test.tfd, which defines a Suprasil "environment".)
(2,816 Views)
Hi GerdW,
Thanks for your reply. Yea I could see the error 7 is originating in the case structure.
I would like to know little bit more than hint.
Hassan
(2,802 Views)
Accepted by topic author HassanIqbal
Hi Hassan,
Use a probe to check the filepath used to call that OpenFile function! (That's called "debugging"…)
(2,796 Views)
