Error 7 occurred when building Exe in LabVIEW2010 SP1
Hi All,
I wanted to build an Exe for my Application. When I created an Exe and give Generate Preview, I got the following warning.
Further, I tried to delete most of the code and give generate preview
I didnt get any warning but I dont know, What is that empty file under data folder? Please explain if any one know the reason
Then I build the Exe, the following error is popped up.
Error copying files.
Source: D:\Test Exe\SC\SubVIs\
Destination: D:\Test Exe\Exe\data\
source does not exist
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488: Nonexistent GPIB interface."
Herewith I have attached the LabVIEW code (LV 2010 SP1) which I extracted from my Project.
I browsed our ni forum and the answers posted couldnt sort my problem.
Thanks for your reply in advance
Charu Praba
Message 1 of 1
(2,864 Views)
