Error -705 occurred at teds_Errors.vi
-705 error means that path to the TEDS template is not good. I use templates from attachement with two accelerometers. Depends of your sensor, you should try both. Before reading the physical channel property, i call Configure TEDS.vi. If you don't do this, you need to configure manually from MAX.
Message 11 of 12
(760 Views)
Thank you for replying and sharing your configuration with me.
Do you have any experiance with PXI 78xxR FPGAs or other NI FPGA types, accessing the EEPROMs Bitstream?
Best Regards,
Matti
Message 12 of 12
(752 Views)
