Error 74 Unflattened From String for VISA Read
BLUF: I am getting Error 74: Unflatten From String: Memory or data structure corrupt. after trying to unflatten a string from VISA read.
Here is what I am doing. I have several data types in a message that I am flattening to a string and then writing to a serial port using VISA. I am using a loopback connector on my serial port to then read what I wrote using VISA read. I am able to read the message in binary, but I would like to unflatten the string and unbundle all of the data types and display each to test my serial transmission. The problem is that I am getting the error mentioned in my BLUF above when trying to do this. Does anyone know how to correct this issue?
Message 1 of 16
(5,747 Views)
Hi Scaz,
check your string for completeness and correctness!
Otherwise give "good" and "bad" examples of your string conversion to let us check them…
Message 2 of 16
(5,738 Views)
I am not sure what you are asking for. I always get ERROR 74 when I try to run the VI. I am wiring the Type connector on the Unflattened From String directly to my cluster of elements that I send to the Serial Write VI.
Message 3 of 16
(5,733 Views)
Hi Scaz,
please provide a VI containing a string with data set to default and your conversion…
To say it the other way: when everything is set correctly the conversion will work without errors. As you get errors you (probably) did something wrong! But without any data/examples/VI we cannot check the source of the problem!
Message 4 of 16
(5,730 Views)
I attached an example of what I am trying to do. This a simplified version of a portion of my code that is giving me problems. The unflatten from string is what is giving me errors. Any help would be appreciated. Thank you.
Message 5 of 16
(5,701 Views)
Hi Scaz,
your VI doesn't contain any string with some value set to default - as I asked for…
But what I can say from your VI: using BytesAtPort is wrong for (atleast) 99% of all use cases! You need to make sure you read enough bytes so yoou can parse your string into the cluster you want it to be!
So again I ask you to provide an example VI with a string containing data you have received from your serial port, which gives errors in unflattening!
And while you're working on this: remove BytesAtPort from your VI. Either use a TermChar (which might be problematic with your binary data) or send/receive messages of known length!
Message 6 of 16
(5,695 Views)
Compare 2 strings GerdW is asking for. (1 - sent, 2 - received). They should be _identical_. If not, conversion will fail.
Untill you receive identical strings, do not blame unflatten.vi
Check what is different between these 2 strings.
Different size, incomplete string?
Some bit order in your data makes LineFeed byte and transmission stops?
Etc...
Message 7 of 16
(5,646 Views)
Maybe something like this would work better?
I'm using two ports and a null modem.
Message 8 of 16
(5,636 Views)
What would be the best way to compare the sent and receive strings?
Message 9 of 16
(5,533 Views)
The "Equals" function.
Message 10 of 16
(5,506 Views)
