Error 74
Hello, Myself a student from RV colllege of engineering, Bangalore, India.
    I was trying to receive data from Xplane 11 simulation software through UDP. But I am getting ERROR 74  occurred at unflatten from string.
Possible reason: Memory or data structure corrupt.
I have uploaded the screenshot of the error and the block diagram along with it. I have very less knowledge in Labview programming and struck due to this error.
I kindly request you to provide support so that I can continue with my project.
Thank You
(737 Views)
As a first suggestion, try to unflatten only if UDP Read does not return an error. Otherwise, you are probably getting an empty string.
I guess you are expecting 18 double numbers with a 5-bytes header?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(705 Views)
