Error 8 Compilation Error. File permission error or DMA hardware error detected
I just upgraded my Labview code to Labview 8.5 from LV8.2.1
Then I tried to compile my code to get an .exe file
I keep getting the following error,
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 8 occurred at Write to Text File in AB_Engine_Update_INI_Header.vi->AB_Application.lvclass:Create_INI_File.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
NI-488:  DMA hardware error detected.
C:\UserData\LabView\IFX Interop Test exe\GMXiTest.ini
I never have this problem if I compile using LV8.2.1.
Please help! Thanks.
(4,452 Views)
hi there
just to be sure: has 8.5 been installed under an other account than yours? make sure you have the windows access rigths to the LabVIEW - folder.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,445 Views)
Yes I have administrator rights on the PC. It was installed with full R/W permission.
I saw in the forum that others are having the same problem and tried this work-around mentioned but it did not work.
http://forums.ni.com/ni/board/message?board.id=170&message.id=172537&query.id=115461#M172537
Any ideas?
Message Edited by nantha on 09-13-2007 06:57 AM
Message Edited by nantha on 09-13-2007 06:58 AM
(4,443 Views)
Hello Nantha,
here you can finde more info about the error 8 code.
Please check the file permission of the file.
http://digital.ni.com/public.nsf/websearch/F5D5F6798A9367CC86256F6C007A968D?OpenDocument
Could you post a small vi so that i could try to reproduce the error.
It would be greate if you could descripe the approach.
Kind regards,
Elmar
(4,418 Views)
