Error 85 occured at Scan from String (arg 1)
Is there an issue with my code that I'm not seeing? Can't find where this error would be from.
Update: Resolved.
Message 11 of 14
(710 Views)
Your data type to unflatten to is wrong.  It should be a scaler I16 or U16.  I did not dig through the document to see which it should be.  My snippet used a U16.  The only difference is if it should be able to go negative or not.
Message 12 of 14
(670 Views)
These should be scalars, not arrays:
Also the numeric representation should be U16, not I16.
Message 13 of 14
(663 Views)
Hi parker,
https://forums.ni.com/t5/LabVIEW/Complete-String-Conversion-Tutorial/m-p/4245188#M1234546
have you read this? Look at Recipe 05 or 06, according to your endianness.
Greets, Dave
Message 14 of 14
(639 Views)
