06-10-2011 02:39 AM
Thanks for your kindly help, The problem is solved. I uninstall the LV and DAQmx, reinstall Both of them, it is ok now.
11-05-2012 11:29 AM
I had the same error and fixed it by uninstalling and reinstalling DAQmx.
09-17-2013 12:57 PM
This document will be able to read analog signals from a DAQ USB6008, this program is useful to read the value recorded by a temperature sensor, the value of voltage or analog signal
07-10-2017 02:01 AM
I recently encoumtered the following error: errror-2147220719 DAQmx Create Channel(AI-VoltageBasic).vi:170001 May you please assist.
07-10-2017 02:02 AM
I recently encountered the following error: errror-2147220719 DAQmx Create Channel(AI-Voltage Basic).vi:170001 May you please assist.
07-10-2017 03:09 PM
Since this forum post is very old and is marked as answered already, you would be best helped by asking a new question on the Multifunction DAQ message board. You can find that forum at the following link:
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
