Error -88303 occurred at DAQmx Control Task.vi:3900002
LabVIEW 2020 64 bit
DAQMX 20.7 version
I am using simulated device cDAQ-9178
Possible reason(s):
An internal error occurred.
Task Name: _unnamedTask<3>
(548 Views)
@_TestMan_ wrote:
LabVIEW 2020 64 bit
DAQMX 20.7 version
Possible reason(s):
Are you trying to run multiple tasks at the same time? For example, running something in MAX and LabVIEW, or tow different VIs that access the same resource? That is the error.
(528 Views)
No. Only running 1 task from LabVIEW. Exact same thing happens on a different computer I tried.
If I try the exact same thing (DAQMX Express VI) in LabVIEW 2018 32bit version, it works fine without any error.
(522 Views)
You can try resetting the device or just use DAQmx functions instead of the assistant. Not sure what else is going on, cannot debug DAQ assistant.
(494 Views)
I deleted simulated device and added back and still the same issue. Works fine on LabVIEW 2018 32 bit as I mentioned.
(490 Views)
