02-27-2015 03:42 PM
G'day
I have a NI USB 6259 connected to a power amplifier and shaker through AO0. I have downloaded the swept sine VI from the NI website to go with the sound and vibration toolkit.
However when I run this VI even though I have slected my A0 excitation channel : Dev1/ao0 the program shoots out the error message:
Error -89120 occurred at SVT Start Swept Sine (DAQmx).vi
Possible reason(s):
Source terminal to be routed could not be found on the device.
Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names.
I have attached screen shots of the program and MAX
Your help is most appreciated
Regards Tanju Yildirim
02-27-2015 03:43 PM
These are the attached files dont know why the previous message wouldn't post them
03-02-2015 06:31 PM
Tanju,
A few quick questions:
First, what version of LabVIEW are you using? What Operating System? Is your S&V toolkit up-to-date? Where did you download the Swept Sine vi from, specifically?
03-02-2015 07:55 PM
I had an older version running with the USB device however I deleted the trigger line in SVT start sine sweep which fixed the problem.
Thank you for replying however
Regards Tanju
