Error -89137 when generating two pulse trains with PCIe-6323
I received error code -89137 when I tried to run the attached VI, but don’t know why it occurs and how to avoid it. I would appreciate if anybody can help.
My DAQ board is a PCIe-6323.
The upper 1/3 of the block diagram is to create a continuous pulse train using wave form, which contains two digital pulses at the beginning.
The middle 1/3 is the pulse generator.
The bottom 1/3 is to generate a finite pulse train using waveform, whenever triggered.
I tried to change the trigger source, but none worked.
If I delete one of the pulse train generators, no error occurs.
Thank you,
shiuyang
(2,549 Views)
This might help:
Why Do I Get a Resource Error When Using a Reference Clock with NI-DAQmx Devices?
http://digital.ni.com/public.nsf/allkb/3D99C0ECBCC9FA9C862576E800556235?OpenDocument
Does your error look exactly like this?
Error -89137: Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
(2,517 Views)
