Error 8aaa1713 in eventoracle.cpp LabVIEW 13
Steps to reproduce:
1. Have 13 parallel loops, each with its own dynamic event registration
2. Have one of your loops experience mysterious VISA system errors (something like BF00)
3. Attempt to inspect error logs, only for the error logger window to freeze.
4. Normal synchronous stop no longer accessible, so abort the main VI
5. LabVIEW crashes.
Last post mentioning this was in 2004. Somehow I feel like that xkcd comic... who were you, Kiebach?! What did you see?
(3,564 Views)
Just captured this screenshot:
ZvXyx5w
(3,562 Views)
First of all, I appreciate the xkcd reference!
Do these VISA errors occur any other time on your system, or is it only when using this VI with the 13 parallel loops?
Is there any way to close out of the error instead of inspecting it and having the synchronous stop be disabled?
This is definitely odd.
(3,508 Views)
hi buddy, did you solve the problem? i am getting the same error code, please help if you got the solution!
(2,833 Views)
