Error -90904 / Load from ASCII
I have a LabVIEW VI containing the "Load from ASCII" module from SignalExpress. Running the VI results in the error message "Error -90904. "Load from ASCII" using exactly the same settings under SignalExpress works fine. What is going wrong here?
Bjoern
(3,584 Views)
Hi Bjoern,
Which version of LabVIEW and SignalExpress are you using?
BR, Christian
(3,561 Views)
I am using LabView 8.20 and Signal Express 1.1.1.
Regards
Bjoern
(3,559 Views)
Bjoern,
I tried to reproduce this problem using LabVIEW 8.20 and SignalExpress 2.0, however this works fine!
I can't find any description or explanation on this error, so I would recommend to download NI-DAQmx 8.5,
which includes SignalExpress 2.0.
Please deinstall the current Version of DAQmx and Signal Express before installing the new one.
BR, Christian
(3,556 Views)
does the DAQmx package really contain the Signal Express installation? I always thought that this is a separate product which is not available for download.
Bjoern
(3,553 Views)
Bjoern,
I'm sorry, this was my mistake!
But, there is a download vor LabVIEW SignalExpress, as follows:
https://www.ni.com/en/support/downloads/software-products/download.signalexpress.html
BR, Christian
Message Edited by Christian_M on 03-08-2007 03:57 AM
(3,552 Views)
