Error 97 in save report to file excel activex
   So I am using both excel activex and the report generation toolbox for excel to format a document. Everytime I try to save the document I get error 97. I can seem to find why and how to fix it. The error means it's a null reference which following my code isn't true. Even when I use the save as activex method I still get the same error.
Please take a look and see if you can help me figure this out.
(4,119 Views)
Hi!
There is a known issue about that : http://digital.ni.com/public.nsf/allkb/37591EDE7A15F5DC86256CC3005BFE35
I ran into this issue with some recent versions of MS Office : it seems that the ActiveX protype of some functions changed. So you have to dig down into the Report Generation Toolkit Excel function to find whcih VI is producing the error and refresh the function protoype... Smiley Sad
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,072 Views)
Can you explain what you are trying to do?  Perhaps provide a (small) example of the data you want to put into Excel, and a (similarly small) Excel Workbook that you hope to make.  It looks like you are interested (perhaps more) in the detailed formatting of the Worksheet rather than getting the data into Excel.
Can you provide a little more information on your configuration?  What version of Office are you using (Microsoft makes changes and doesn't always tell NI)?  There have been reports of problems closing/saving with Excel 2016 -- I've not experienced any problems with Excel 2013 and earlier versions.
Bob Schor
(4,057 Views)
Hey Bob,
   My goal is to color the  headers of both files and format all the cells size and border and font.. Then I want to look  in data1.csv and check if values in column J is 50% of column I. If it is then color the whole row red. If the value is between 10-50% the color it yellow. then save the files with the latest formats. Hope that helps.. files are attached. I am using Microsoft 2010 with labview 2014
(4,050 Views)
There seems to be a timing issue between the 2 save report vi where the workbook reference get lost. I did a simple modification to test this and I didn't get the error by running the vi continuously. This is only a quick patch so there should be a better way to implement this.
Ben64
(4,037 Views)
Thanks Ben.. I'll look at it.
   I did manage to get it to work by starting over and using only vis from the report generator. I also cleaned it up and fix some mistakes I made...I'll post my version later.
(4,033 Views)
