Error Between Loading and Saving
Hey all. When I save a file as a .vi or a .exe, it loads perfectly fine and runs using Labview 2015, 32-bit on my laptop. I have to open these files on a seperate computer to run my files on a test set up, and this computer has a 32 bit version of the runtime engine and drivers, and gives me an error message when I try to load my files. It tells me to check the version of Labview on the computer (on the second computer) but I know they are the same version. ANyone have any ideas on what I should do?
(4,153 Views)
Can you be more specific on what the error says?
(4,150 Views)
"The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64(64-bit) version" I'm fairly certain that both computers have the 32 bit version.
(4,138 Views)
-Right click My Computer and see computer information and post screenshot of what bit os installed in both PCs.
-In program files please verify whether you have same run time engine with bit information.
-what other drivers you are using? Check that bit version also.
uday
(4,128 Views)
