Error Code: 1, Bluetooth Link
Hi, I am running a LabVIEW .exe on Windows XP which reads in 6 bytes of Bluetooth data every 1 minute.  I had the program running continuously for 11 hours, then received a "Error Code: 1".  I don't know what this is, does it have something to do with a memory issue?  I restarted the computer and started the program again and it worked fine.  Thank you.
(2,805 Views)
Error 1 isn't very specific.
What did the test for the error say and the possible reasons section?
TimC
(2,779 Views)
