Error Code 200043
I received this warning while running my Lavbiew Program.
Error 200043
General
Software Error
The error occured at DAQmx Start Task.vi
Date specified by the channel Calibration expiration date property has expired. The channel calibration is applied in spite of this because the apply calibration if expired is set to true.
I went an checked the properties of all my Start Tasks in Labview and in MAC (Measurement and Control). I was unable to find a expiration date property.
I hope someone is able to help me out. Thank you for your help in advance.
Best regards
Kaushal Shah
(3,243 Views)
Kaushal,
This is a property of global virtural channels in MAX.  If you select your virtual channel, there should be a tab called Calibration on the NI-DAQmx Global Channel tab.  Here is where you can set your calibration settings.
If you want to access these properties in LabVIEW, you can use a Channel Property Node on the DAQmx palette, and select the class as shown in the image below.
Drew T.
Camber Ridge, LLC.
(3,227 Views)
