Error Code -50101
Hi to aeveryone. Using C-RIO, while trrying to communicate beetween host VI and FPGA VI to excanghe simple data, the execution stop and appear this message:
 Error -50101 occurred at _nirio_device_getDeviceHandle.vi:2
Possible reason(s):
The requested resource does not exist or exists but is in a state which prevents its reservation. The operation could not be completed as specified.
I open the refer to FPGA with "Oen FPGA VI Reference" block, then I use a simple "Read/Write Control" to exchange data then I close the FPGA reference...It's a simple VI only to test the hardware setup (i'm a newbye...)...and it' doesn't work...any suggestion?
Thanks a lot,
Ste
(4,451 Views)
Hi Ste,
usually the error you are getting stems from a software version mismatch between the Host and the cRIO. As suggested in the following 2 KBs, you should check that ni-rio versions on Host and target are the same and eventually upgrade the version that fell behind.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QL7SAM&l=en-US
http://digital.ni.com/public.nsf/websearch/7F577BAB22E70A4E862570B4007BE87A?OpenDocument
AlessioD
(4,440 Views)
