Error Code
Hello, I was wondering if anyone could help me with my error.
The program ran fine yesterday, and there was no modification to the setup from yesterday to today when that error popped up. Also since that error popped up i changed out the DAQ and the chassis that it is on and I still get the same error.
Message 1 of 12
(4,204 Views)
Hi SG,
which program did run fine until yesterday?
Did you try to debug this program?
Message 2 of 12
(4,186 Views)
Did you try to restart the computer? Did the IT group push an update? Did Windows update?
Tim
GHSP
Message 3 of 12
(4,176 Views)
The same Labview program the operator uses to test valves with. No I have not tried to debug it.
Message 4 of 12
(4,149 Views)
Yes the machine has been restarted several times actually. There were no windows or IT updates
Message 5 of 12
(4,148 Views)
Can you do a self test of the device in NI Max? Is so does it tell you that it is functioning properly?
Tim
GHSP
Message 6 of 12
(4,142 Views)
Error 7777 is in the User Defined Error range. Search your code for this error number.
Message 7 of 12
(4,131 Views)
The self test button does not show up.  :c
Message 8 of 12
(4,121 Views)
OK so I messed around a bit with it, and the self test- button shows up and it says test was successful, but i still get the same error when i try to run the labview program
Message 9 of 12
(4,050 Views)
When you get a runtime error, keep in mind that it is happening due to programs that are conflicting with each other. The first thing you can do to resolve the problem is to stop these conflicting programs.
  • Open Task Manager by clicking Ctrl-Alt-Del at the same time. This will let you see the list of programs currently running.
  • Go to the Processes tab and stop the programs one by one by highlighting each program and clicking the End Process button.
  • You will need to observe if the error message will reoccur each time you stop a process.
  • Once you get to identify which program is causing the error, you may go ahead with the next troubleshooting step, reinstalling the application.
Message 10 of 12
(4,028 Views)
