Error FPProtocol.cpp line 3244 using remote panel and subpanel
We are developing a remote panel application using LV7.1 for WinXP.  One of our UI's uses a subpanel to embed other smaller, task-specific, UI's.  This generally works quite well.  However, one of these task-specific UI's will generally cause one of the following problems:
a)  As soon as the subVI panel is exposed in the subpanel, "Error FPProtocol.cpp line 3244" occurrs.
b)  The subVI panel is exposed in the subpanel, however the user loses control over the entire remote panel.  One work-around to this situation that seems to work is:
(2,687 Views)
This looks like a duplicate of this post.
Scott Y
 NI
(2,675 Views)
