Error Generated Using LabVIEW Application Builder with "Enable ActiveX Server" Option Checked for lv2012 error code 1547
i have develop a program and can be builder success,and when i check the option of  "Enable ActiveX Server",then error is occured,the error no is 1547 and display
the following string:AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller's calling point.does anybody have met the problem and help me?thanks very much.
(3,712 Views)
This is a bug for  LV 2012 Chinese version which was fixed in SP1. You can either update your LV or just used the English version.
(3,582 Views)
I am getting the same error in LabVIEW 2015 SP1 English version
on Win7 Pro 64 bit English OS.
George Zou
(3,255 Views)
