02-12-2013 07:36 AM
Hello together,
I wanted to use a Sanyo Xacti CG 10 video camara in LabView.
By using the NI-IMAQ for USB Snap I get the following error: IMAQ Vision: (Hex 0xBFF60492) Ungültige Blit-Funktion des Videoausgangs.
Is it possible, that I can not use this camera in LabView?
Driver are up to date for the camara and IMAQ.
Thanks a lot for your reply
Solved! Go to Solution.
02-14-2013 02:43 AM
Hey KvonK,
some further information would be helpful for me and the other people in the forum. Can you see the camera in MAX? Is it possible to get a picture from the test panel in MAX?
It would also be very helpful, if you post the used VI.
And because I understand the german error text: Is "Blit-Funktion" the real error message text or only a typing error?
Regards, Stephan
02-14-2013 10:49 AM
Hello Stephan_D,
thank you for your answer.
I can see the camera in MAX and it I can see the video directly (Attachment)
The name of the used VI is "NI IMAQ for USB snap_VBAI stab.vi".
The error which I get with this VI is :"IMAQ Vision: (Hex 0xBFF60492) Ungültige Blit-Funktion des Videoausgangs.".
I tried it also in the NI Vision Builder, but there I get only the mistake "No NI-ImaQdx Camera Connected".
I hope you can help me.
Best regards
Christian
02-18-2013 02:10 AM
Hi Christian,
please try to acquire a image with the attached VI. Do you also receive a error message with this programm code, if you choose your USB Sanyo Xacti CG 10 and run the VI?
Regards, Stephan
02-19-2013 02:13 AM
Hello Stefan,
thank you for your reply.
With this VI I am able to get the video from the Sanyo Xacti CG 10 into LabView.![]()
In this way I can proceed the data in my way.
Best regards
Christian
