Error Inicializating a VISA sesion
Dear collegues,
when I run the Easy Visa Find Resources VI, with the option Find All GPIB
devices, the program returns me the error
code: -1073807343, which means: Invalid Resource Reference Specified.
Parsing Error.
I don't understand clearly the reason for this error. I've two GPIB
devices connected to the GPIB port which work properly.
In addittion to that I've downloaded the NI-VISA drivers but still I've the
problem.
May be the problem is because I've an old GPIB board (CEC 488-2) which
doesn't work with the GPIB Labview drivers. In this case does anyone know
any solution?
Thank you in advance
Jordi
(2,753 Views)
NI-VISA works with gpib cards from National Instruments. You will need to get a VISA distribution from CEC and then the LabVIEW VISA functions should work OK.
(2,753 Views)
