Error Loading NI_AALBase.lvlib:Mean.vi
Hi Dennis
Thanks for the reminder.  I have a Data folder with the correct dll in it.  I have done a clean install of both PCs (dev and deploy) so both only contain LV 2009.
Cheers
Bryan
Message 11 of 12
(1,450 Views)
I think Mishkin (Post 4) was on the right track however that info does not apply to LV 2009 (as far as I can see).  As LV changes alot, it seems the documentation does not keep track.  The UI has changed significantly so many of those fixes from LV 7 and LV 8, don't work as the UI has changed.
Bryan
Message 12 of 12
(1,449 Views)
