Error Message box pop up
HI Again,
Here is another question. How do I get the "Display Message to User" to pop up in front of all windows? Right now, I have to open the minimized progrm to see what the message is. How do I automatically get the message on top of all windows, Thanks!
Vj
I may not be perfect, but I'm all I got!
(6,425 Views)
(6,409 Views)
Sarcasm??? I'll take it... 🙂
(6,403 Views)
Good. Because I've got plenty to give away. Smiley Wink
(6,388 Views)
Be very careful on how you handle pop up windows!  Bad things can happen if you do not take care of things properly.Smiley Surprised
(6,385 Views)
Hey Guys,
IsFront property bring the error pop up on screen; but it is still behind the other software I am running.
What I have is two programs running; one is a LabVIEW program and the other is a commercial software; both communicating with each other through RS232. The commercial software hogs the screen and unless I manually click the LabVIEW taskbar, I am unable to bring it to the front of the screen.
Is there any other way to overcome this?
Thanks!
(6,325 Views)
Then you need to use operating system calls to get the window to the front. On Windows you can use the Windows API Function Utilities (32-bit) for LabVIEW
(6,317 Views)
