Error Message "not a valid Windows CE application?"
I build an executable using PDA module and try to open it up on Pocket PC, but it says "FILENAME is not a valid Windows CE application" every time.  Can any one give me a pointer or two?
Do I have to install a thing or two onto the Pocket PC system before doing anything?  I am using Windows CE .NET 4.2
hellolv
(7,479 Views)
What version of LV PDA module are you using? If I am correct, you are probbaly using LV PDA 7.1 or 8.0, none of which support Win CE .NET 4.2. You would need to use LabVIEW PDA 7.0 in order to use it with a PDA running Win CE.NET 4.2 OS.
Ankita
(7,464 Views)
Where can I find any documentation on this kind of info?  What should I use with Labview 8.0?  if CE .NET is not going to work....
Thanks.
(7,458 Views)
The best place to get started with the requirements is the datasheet. You can also find the information in the PDA module manual.
I’m not convinced that a previous post was correct (http://forums.ni.com/ni/board/message?board.id=170&message.id=160316&requireLogin=False).  Have you seen this tutorial for Windows CE?
I apologize for the confusion!  Please review these documents and let me know if you have any additional questions.
Travis M
LabVIEW R&D
(7,443 Views)
