Error Message when I use DAQmx Read
My PC keeps popping up this message Fatal error:"memory manager.cpp",line 566.I am using labview version 10.0 professional.
Please i need assistance to resolve it.Thanks.
(2,706 Views)
Hi Nolimit,
The first course of action would be to repair the installation of your DAQmx drivers.  You can do this through the Measurement & Automation Explorer (MAX).
Navigate to 'Software' in the left pane then click 'Change/Remove Software' in the right pane.  A window should load where you can select your NI-DAQmx drivers for repair.
Let me know how this goes!
Lewis Gear CLA
LabVIEW UAV
(2,683 Views)
hi
as lewis said you can use MAX . But if you want to use only Labview try reinstalling your Device Drivers . Please do revert for clarification.
bharathwaj
AE india
(2,675 Views)
