[Error] Property node (visible) of cluster elements
 I want to make some elements of the cluster visible/invisible depending on the input. All this is in a subVI and it works inside the subVI as you can see in the gif.
But on the front panel of the main VI, it is not working.
Do you see what am I doing wrong here?
(2,949 Views)
Have a look at this old post for an idea of how to create array references for your clusters.
https://forums.ni.com/t5/LabVIEW/hide-and-make-visible-a-group-of-buttons-controls-or-indicators/m-p...
Patrick Allen: FunctionalityUnlimited.ca
(2,935 Views)
