Error Report SQL database by LabSQL
hi all, i want to ask about error report by LabSQL, i made i program monitoring 12 machine in 1 program, i made SQL database by LabSQL freeware Smiley Happy
in this case the database can work correctly,
look on the date of database, it made 5 row ( every 1 hour plot the database ) so it only 5 hour the program running, the connection on LabSQL has an error report like this:
what the problem ? please explain to me what the problem. help me correct my program, i`ll attach my program,
on this case i can only use LabSQL because we no have much money to buy Database connectivity toolkit, please help Smiley Sad
(3,653 Views)
Accepted by topic author rhiesnand
If you look at the description of the error, it says there are 'too many client tasks' - how many SQL references do you have open at a time? Are you trying to write to the database from multiple places by opening and closing the reference each time?
(blog)
(3,622 Views)
The error message tells you all you need to know.
You have too many ADO tasks runing at the same time.
 From what I can see, you are opening a lot for connections to the same database at the same time. And you are opening and closing them for every loop iteration.
Try to change you design to a producer/consumer, where the consumer is the only one that has access to and store data in the database.
(3,614 Views)
hey guys ! i forgot to use ADO Close on that program, so the communication always running and the task will be increase continously, right ? so the problem has been solved ! thank you very much Smiley Very Happy
(3,575 Views)
