Error: Source file format invalid. Labview NXG
Hi everyone,
I'm working with LabVIEW NXG and I have problems with files: I create a file, save it and then when I try to reopen it, LabVIEW gives me the following error message. "An error occured while trying to load "namefile.gvi". The source file format is invalid." I don't know how to recover the VI. I tried to create a new file, but the error keeps coming back.
Thank you
Federica
(1,838 Views)
Hi Fede,
How do you "create" the file?
Which kind of "files"?
(1,835 Views)
I create a new VI on LabVIEW NXG and then I save the project and the VI inside it.
(1,811 Views)
Hi Fede,
Two comments:
  • LabVIEW-NXG is "end of life" and doesn't receive support from NI anymore. You better switch to "classic" LabVIEW! Btw. which version do you use?
  • Why don't you attach your project and gvi so someone else with LabVIEW-NXG can test your problem?
(1,782 Views)
