Error:The specified network address is currently in use when exe file is run
I get this error(above) when i run my executable files.My exe file is in directly in c:\codes\application.exe. After this, i also like to know how do i enter the URL in a web browser to access this exe file. I have created and change the labview.ini file to application.ini and put it in the same directory as my exe file already.
Kindly provide me with a detailed solution to solve this problem. Thanks
(2,914 Views)
I am not sure what you are doing but I think this is the information you are looking for:
Can I Make My LabVIEW 7.0 Executable Use Remote Front Panels?
There are several other simmlar pages on the web. I went to Advanced Search and looked for executable remote front panel .
(2,914 Views)
