Error Transfering Matrices from MATLAB to LabVIEW
Hello Everyone,
I have just started working in LabVIEW. I need to make an interface between MATLAB and LabVIEW.
I want to calculate new matrices and vectors everytime in MATLAB and pass those to LabVIEW for QP-optimization.
My MATLAB script node looks like the following :
for i =1:x
for j=1:y
 a(i,j) = i+j;
end
end
where x and y are control inputs from Front Panel and "a" matrix is need to be used in LabVIEW.
When I am running this, an error occurs as :
"Code 1050
LabVIEW:  Error occurred while executing script. Error message from server: ??? Error: Unexpected MATLAB operator.
. in MATLAB_Script.vi"
I have the required .dll files in the required folder and also the destination directory, the MATLAB wants to open, I have set it to same.
I do not know why is this error is coming.
However, when I am doing simply "a=x+y" the code runs properly. So, I doubt if the matrix and vector tranfer need any special syntax.
Please help.
Prashant
Message 1 of 1
(2,640 Views)
