Error While Reading a file Dynamically in CRIO - 9073
Hello all,
          I am using CRIO - 9073, here i transferred a file (With size of 5mb) through FTP from my PC..... and then i am trying to read it Dynamically, but while i am reading this file and updating, my CRIO going to stop mode...... So i can't workout more... Give a fine reply all...
Regards
Pandithan.
(2,643 Views)
What code for path building do you have running on the CRIO?
Ton
My LabVIEW Ideas
(2,632 Views)
Hi Ton,
I used a standard Build Path from Functions Pallette....... to specify the file path....
Regard's
Pandithan,
(2,620 Views)
