Error accessing Remote Front Panel on RT Target after upgrade to LV2011
I'm upgrading a real-time application (target is a desktop PC running the LabVIEW real-time) from LabVIEW 2009 to 2011.  Under 2009, it was possible the view the main VI remotely by browsing to a static HTML page that embedded the front panel.  After upgrading to LabVIEW 2011, instead of the front panel image I get an error saying "Server does not support Remote Panels."  I have already gone through the list of possible causes from "Server Does Not Support Remote Panels" Error When Connecting to Remote Front Panel, and none of these resolved the problem.  I am using the standard LabVIEW web server, there is a direct ethernet cable connecting my computer with the real-time system, and I have recreated the web page to reference the correct plug-in version.  I reformatted the RT system and then did a clean install of the components from LabVIEW 2011 (using the Add/Remove Software feature in Measurement and Automation Explorer).  I also created a new test project with a new simple VI; I was able to access that VI remotely on port 8000, but not on the default port 80 (which used to work under LabVIEW 2009).  What changed in the web server between LabVIEW 2009 and 2011?  Can I use the standard HTTP port 80 to serve a static page with an embedded VI, or does this now only work on other ports (and if so, why)?  Will I need to recreate my entire project in LabVIEW 2011 in order to get this working at all?
(2,665 Views)
Got it working, after much experimentation.  Seems to require installing exactly the right combination of items on the RT target, as some items (web services? web configuration? the "application web server"?) apparently run a separate web server - or instance of the web server - on port 80, which prevents remote front panels from being served on that port.
(2,655 Views)
