Error after 29 hrs
I'm running LabView 2017 64-bit which calls a TestStand 2016 64-bit sequence
After running for approximately 29hrs the Operating System shows an Event Failure
- EventData
LabVIEW.exe 17.0.0.4011
59947661
NiViSv64.dll
17.5.0.49152
59ef657f
c0000005
0000000000003123
2330
C:\Program Files\National Instruments\LabView 2017\LabVIEW.exe
C:\WINDOWS\SYSTEM32\NiViSv64.dll
34b6980f-d189-4ca4-aef3-08bfe5d36509
Message 1 of 10
(4,320 Views)
Check your power saving settings for any comm port you may be using.
Ben
Message 2 of 10
(4,312 Views)
I've double-checked the Power Settings.
The only thing I believe I missed was a default setting on the USB port, which I've now disabled.
I'm about 6-hrs away from determining whether this is the answer or not.
Still looking for additional suggestions.
Any theories on the DLL ?
Keith
Message 3 of 10
(4,298 Views)
Keith
With the scares info you provided, the wild guess about VISA failing if the power saving options are active is the only idea that I can offer.
Now if you provide more information... maybe someone can say more.
Ben
Message 4 of 10
(4,281 Views)
Additional Information:
Main Application is LabView
This App uses the example
C:\Users\Public\Documents\National Instruments\TestStand 2017 (32-bit)\Examples\Modifying User Interfaces\Creating a Basic User Interface\LabVIEW
It calls a TestStand Sequence which contains a combination of LabView routines as well as .NET calls
The Main LabView application uses Messages to pass data between the UI and the Sequence to update FileGlobals, as well as Indicators.
I understand this is fairly cryptic. If more details are required then I will provide as much as I can with security concerns
KM
Message 5 of 10
(4,229 Views)
See here for a KB article that may help.
It speaks of an access violation "c0000005 "
Clearly winging it...
Ben
Message 6 of 10
(4,210 Views)
In addition, this occurs in
NiViSv64.dll
I was hoping that someone would have a bit more information on this dll
KM
Message 7 of 10
(4,190 Views)
NiViSv64.dll
What kind of information are you looking for?
There's this.
Message 8 of 10
(4,165 Views)
NiViSv64.dll
KM
If you check the properties of this file it says that it is the NI-VISA Library Service, so most likely a collection of library routines used by the NI-VISA software.
So it would seem that something goes wrong when doing VISA communication, which leads us back to USB power saving troubles as a possible culprit.
Rolf Kalbermatter  My Blog
Message 9 of 10
(4,153 Views)
Ben
Sometimes the (internal) USB hubs have power saving settings too. Those might need tweaking as well.
Message 10 of 10
(4,148 Views)
