Error attempting to connect to the compile server
Hai all;
I have design a project consists of fpga.vi and host.vi. When I try to compile the fpga.vi and select the server, an error occurred said "An error occurred attempting to connect to this compile server". I use single board NI-sbRIO. I have check the connection in Measurement & Automation Explorer and the device is connected. Why this error come out? Anyone please advise, I attach the figure.
Thank You
(4,298 Views)
Do you have the Xilinx Tools installed?
Christian
(4,280 Views)
Thats error occur when I compile the VI in my notebook. But, there is no problem when I compile it in PC.
Maybe I miss some installation in my notebook. Thanks for response
(4,278 Views)
Yes, it seems that you miss the Xilinx Tools, as I said before.
Christian
(4,276 Views)
Yes you are right. Thanks. Btw, I get new error about IMAQ and I have post it as a new thread. Hope you can give advise.
(4,274 Views)
(4,274 Views)
Hi, I also meet this problem even though I already installed the Xilinx Tools. My labview version is 2013 and the Xilinx Tools version is also 2013. Should I install Xilinx Tools 2014 and it can solve this problem?
best
(3,992 Views)
