10-04-2006 06:57 PM
10-05-2006 10:50 AM
10-09-2006 08:37 AM
Mike,
Thank you for replying. You are correct about the source distribution. I wanted to try a different approach to distributing to computers without the hassles of just saving to a directory and renaming and duplicate copies of VI's. The problem is i sometimes write the program at home, debug in the lab, and then rewrite at home. I normally do not need to transfer the application until test time, which can go on for months and future programs need written with my memory stick. I thought creating a source distribution would do the trick, but to be honest I have no clue what that means. I am tired of naming a VI like "RPM Trigger...RPM Trigger1...RPM Trigger2" etc. It is getting confusing especially when it prompts me to view or discard a VI already in memory...which one again?
ANY help or general knowledge of how "normal" programmers do this.
Back to the project. I had moved several VI's that were in my project around on my hard drive to reflect the same organization scheme. I also believed this to be the culprit so i recompiled each of the first level VI's and resaved. That was an exercise in futility. If nothing else, i have learned a VERY valuable lesson- keep the project organized and Directory organized and in the same way from the very start!
I am programming with 8.0 full version, ready to install 8.2.
Sorry so long, and thank you for helping
Chris
10-10-2006 04:54 PM
