Error code 100 - erroneous data
Hi everybody,
When I try to read a Labview measurement file I sometimes get the follwing error: 'Error 100 occurred at Read LabVIEW Measurement File -> File_Convert.vi. Possible reason: LabVIEW: File contains erroneous data. Normally for user data files.'
However I have no idea what is causing this error and what I could do to resolve this problem. Should I look for a certain character in the LVM-file and remove it? For an example of a VI and a file that causes this error look in this discussion thread: http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000087CF0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Thanks in advance for your help.
Paul Perreijn
(7,066 Views)
Same problem. bump
(6,415 Views)
me too!!!
(6,218 Views)
I also have this issue and its rather disappoining to see that no one has returned a solution or even tried.
In my case I have Created an initial values array using math script and then output the values to a write measurement file; later on I use Read measurement file pointing at the same location to retrieve initial values and this is the point in which i am getting the error
(6,120 Views)
final atachments
(6,119 Views)
