Error code : -1074003958
I created an exe to use it on a PC without labview
For that I instaled the installer too, and  once I run the file exe I got the error code -1074003958
and the folling message error : rsspecan_core.lvlib: rsidr_core_create_error.vi<ERR> rspecan_att_detector_type
Error elaboration: cannot find dynamically callded back rsspecan_detect or type_rande table callback
Make sure that all VIs are in correct folders. If deploying folder structure has to be maintained
I don't see what that means. May anyone help me please
Thank you in advance
My best regards
K.Nadia
(3,526 Views)
Accepted by topic author k.nadia
Hi, I found an application note with aproposed solution:
page 43
http://cdn.rohde-schwarz.com/pws/dl_downloads/dl_application/application_notes/1ma228_instruments_la...
I'd like to now how well the R&S devices work with LV?
(3,506 Views)
Thank you so much, you save my day
For R&S device, I'm using FSH8 and the advantage of this device , we access via labView using both USB or Ethernet
It's efficient for our need
(3,487 Views)
